Oil in coolant reservoir
  Renault Twingo rs
I was just checking the fluids on my Twingo RS and I discovered that there is oil in my coolant. But not the other way around. No Mayo on the oil cap/dipstick, no smoke out of the exhaust, no power loss and it runs just fine. Could it be the headgasket? I have found some threads where the thermostat housing could be the problem?
If it is still running correctly, and you're not seeing mayo in the oil cap, I wouldn't worry too much.
Perhaps do a coolant flush and then change the oil and coolant - then you can keep track of if it comes back to any great extent.
In my book, if it's running, don't worry until it breaks ;) :D
