oil leak under car on sump
i dont think its comming from the sump plug as its dripping down the whole sump from the engine bay.what could it be?anyone ever had this porblem on a rt? could it be sump gasket?
yeah my RT leaks quite alot 2.
i think mine might b leakin from the head gasket :( :( :( :(
hope no like!! but its fine as long as u check oil every so often.
why are 1.4 energy engine so leaky?????
i had a 1.4rt engine and i had the same leak, put it down to the sump gasket, when i took my engine out thats the only place it was leaking from not the headgasket. but get a gasket set and change the rocker gasket and sump gasket, that will solve it im 99% sure
headgaskets are easy enough to change and you can change the rocker cover gasket while your there.
