-00 Clio 172 Mk2 ph1
I have a strange problem with my Clio Mk2 Ph1 172. Oil is coming out from where the oil dipstick tube is connected to the engine block. When I pop the hood the front side of the block and also the electric fan is sprayed with oil.
This problem only occurs when driving, I can not make it happen when standing still with the hood open. Im guessing this is because the oil sits still in the oil pan when the car isnt moving.
Shouldnt there be an o-ring or something similar on the tube to prevent this problem? How do I get the tube out to check the seal, without removing the engine from the car?
