I wonder if anyone has any ideas what could be causing the following.
I was driving home from work a couple of weeks ago, went over a speed bump a bit quicker than I normall would probs about 5mph more and a bit of a bump.
A mile down the road my STOP and oil warning lights came on, I pulled over and turned the engine off, turned the ignition back on pressed the button to check the oil and it showed as full.
Started engine and drove home which was about 13 miles and not a sign, checked the oil later that night once it had settled and was just under the MAX mark, so ok.
It hasn't come on again untill today, was driving from home to gaz's (gazeratti) house, only about a mile from home and same lights came on, turned engine off, turned ignition on, prssed button and showed oil as fine again, turned engine back on and all was fine, then it did it again about half an hour after, same again, when I turned engine back on it was fine and hasn't come back on.
Anybody got any ideas what it could be?
Fault sensor, loose wire?
And is there anything I can check using the OBDII port?
Thanks,
Al
Thanks,
Al
