Oil Pressure
Car  Clio Sport 172
Hi,
I want to know the oil temperature and the oil pressure in my 172 mk1. Has somebody a picture of where to insert a sensor for the oil pressure (They are quite large)? Is it a good idea to put a plate between the oilfilter and the engine block (I hope you understand what I'm trying to say...)?
Ive only ever seen them with the plates.....
Cant help with readings though, as i dont ahve one
Hope this may be of some use.
http://www.cliosport.net/forum/showthread.php?t=322832
http://www.cliosport.net/forum/showthread.php?t=325852
http://www.cliosport.net/forum/showthread.php?t=323781
http://www.cliosport.net/forum/showthread.php?t=325847
I had a Gauge setup in my Ph2 172FF, only problem i had was the t piece for my gauge senders to screw into was leaking where the senders screwed into the t pieces female threads :(
But i can imagine there will not be much difference in the setup on a Ph1 172.
