Oil temp gauge will depend what oil temps you want to read. You can either fit it inline pre or post cooler......if you have braided cooler lines though it'll cost you a lot more for unions and fittings.
Pressure just get an extension made to fit the original location for the pressure warning sensor, then remote locate a T block with the required threads for the OEM and aftermarket pressure sensor. Remote location prevents failure of the pressure sensor due to NVH.
Its not hard getting the right fittings. A motorsport company is more likely to have the required parts than your average hydraulics company.
NVH = Noise, Vibration and Harshness......basically shaking things till they break.
Dont touch DT for fittings lol.
Call Derek at flexolite.
http://flexolite.co.uk/
Significantly more helpful than any of the 'bigger' companies.
Ok cheers
I don't suppose you know if the standard oil pressure sensor is M14 do you Ben ?
Or if theres any way of knowing/finding out what it is ?
