Fletch123 said:Should i trust the oil indicator on the dash, or should i always check the dipstick?
edde said:The engine allowed to burn under Renault spec 1 liter ever 600 miles.
SOme people have had dodgey sensors get it chnaged under arently assuming you still have one.
Leeshez said:I have done nearly 11K and never put a drop in it. Werid it has never gone down.
Well if your car burns more than 1 liter per 600 miles then Renault will say its a fault. In reality they'd have a look if you burned more than 1 liter per 1k as that a fair bit.Floodie said:Old thread revived... but Edde, are you saying that if your warning light came on, then you put in 1 litre of oil that 600 miles later the warning light should come on again yes?.. i seem to be putting a litre of oil in every 800 - 1000 miles
