(servo motor was faulty and damaged plastic teeth on heater box)
You guys are lucky you have something to put the cable tie/jubilee clip onto!
I have the same problem on a Clio V6 and the connector is recessed. This is what it looks like:
put the back plate on on its own. then add the motors on seperate then u can line em up, if u have it all off id do the fix as prevention
Hello![]()
This little chappie is the spindle for the heater control flap - as you can see it has been split astunder in true Clio fashion... the silver shaft is the steering wheel column, this is a job best not attempted by the tubby/clumsy/profoundly incompetent...
7mm tiewrap applied to keep it together, getting the cover back on here again was a right faff - have to line up two splines in the right place at the same time - right down by where your left foot normally lives...
