This is the spec from the advert;
Car has had a lot of time and money spent on it, Its main feature being an engine conversion from a mk1 citroen saxo vts 1.6 16v which makes it a very quick little thing for the size/weight of it, Its being completely stripped out EVERY unnecessary part has been removed to save weight as this is a track day car,
Car has some mot march 29th 13, So could be driven back if taxed (currnetly has no tax, I cant tax either as im no longer insured on the car)
Its just been fitted with a new cluth and a low mileage saxo vtr gearbox due to the thrust bearing going and the car jamming in gear (receipt to prove)
Here is a list of the mods off the top of my head:
saxo vts engine, saxo vtr gearbox with new clutch (mileage unknown on either engine or shell due to the car been fitted with saxo clocks)
421 raceland exhaust manifold
cda induction kit
engine bay sprayed and car fully waxoiled
straight through performance exhaust
unlocked ecu
modified top engine mount
apparently its running newman ph3 high lift cams although ive never had the covers off
saxo radiator and fan (fan is wired to a manual switch within the car)
push button start (sometimes button takes a few pushes but it always starts)
two sparco bucket seats
luke 4 point harness
bonnet raised kit
bonnet shutter clips
racing steering wheel and boss kit
citroen c5 super light steel wheels
drilled and grooved big brake disk conversion, still drum on rear
lowered all round about 50mm at a guess not sure on make of the springs of dampers
braided brake lines
car has a very small oil leak from the rocker cover gasket, (common on this engine)
Thats about all i can think of at the moment, But il add if i remember anything else as the auction goes on,
Please remember this car is over 20 years old any rust has been seen too its been built by the previous owner for one purpose," Track car" but road legal at the same time its still on the logbook as a 1.4 new owner will have to amend this if they wish,
I was planning on tracking this car myself but due to my girlfriend falling pregnant i have to sell both my cars for a sensible every day one, Weight figures i was told 660kg and power figures 152bhp not sure how true they are but i can say this car will give alot my powerfull cars a run for there money its rapid as you can imagine,
