Outer CV joints
Car  RenaultSport cup172 TT309
I know this might be a silly question, (obvious answer) but are the OUTER cv joints the same on both the o/s and n/s ?
Can i fit a n/s (outer) joint on to a o/s driveshaft ?
(Mk2 172)
My o/s cv joint is knackered. The ball bearing carrier cage has smashed, but the rest of the driveshaft's ok. (I'll explain later how n why, if you're intrested)
I can't see a o/s shaft for sale (used) only a n/s, thought i could use the joint off one of them ?
I'm skint to say the least, just been made redundant, last week. Merry Christmas eh ?
im sure they will be the same outer joint used on both sides.only thing that might be diffrent is the number of teeth on the abs ring.
Real men dont need abs !! lol lol
Its a 172 cup,without ABS.
Thanks, i think i'll give it ago unless a o/s shaft comes up soon.
i'm 99% sure you can't buy a CV joint for them, only a driveshaft (i just replace the driveshaft anyway, saves fooking about)
I agree 100%. But like i said i'm not far off broke ! Think i'll give it a couple more weeks n see if a used o/s one comes up.:(
i've got quite a few kicking about, but IIRC the cup has a different o/s shaft to a normal one, i'll have a check
