Outside temperature not showing
Car  Ph2 172
Had the car a few weeks and the outside temperature has neer worked. There is no reading at all on the display on the dash.
Anybody help?
:rasp:
I have similar problem with mine, it was reading 58C two weeks ago..........
A wrong reading seems to be a more popular problem. I think you need to just change the sensor. £40 from Renault though!
My problem is slightly different, I have no display at all!
change your sensor, it might display the temperature again! 40quid!!!! get a re-fund if it doesn't work!
Think I may check the witing to the nipple. How do you get to it? Do you take the painted cover off the front of the mirror first? Then what?
Cheers!
