Painting Renault Badges, Rub Strip Badges...help
  RS Clio 200
just interested to find out how easy it is to remove the front and rear renault diamonds so i can paint them up.... also the rub strip badges as i wanna paint them too....
having my 172 alloys refurbed in anthracite, with the renault diamond orange, so wanna do all the above orange too.
  Chocolate Bar™
front renault diamond will pull off. so will the side badges
rear badge needs to be unbolted from the inside, and then masked carefully but its definetely do-able
Pep
Living Dangerously
  M2,XJS,S1000RR
the rear badge is fairly easy to take out, take off your rear plastic trim, then unclip the bent metal rod that goes to the lock from the mechanism, it comes out easy enough, and then there are 3 bolts, undo these and pull off the exterior handle, it may be tight because of dirt in the edge, but it will pull off, im not sure if the renault dianond unclips from the handle or not, but even if it doesnt masking is a lot easier!
Pep
Living Dangerously
  M2,XJS,S1000RR
chris turbo, love the yellow, should look awesome mate!
