Painting the front grills
Car  RB182 & Storm 200
Im thinking of painting both fronts grills black, they are currently grey but looking a bit dull. Is it worth sanding first using primer before spraying?
i just sprayed the grills on the wife's scenic and just cleaned them and sprayed them with plasti kote
its not going to hurt you, helps the primer key into the plastic, use an etch primer eats into the plastic better too.
