Have just noticed a vertical dint in the passener door about 2 inches long and very slight. Only seen in some lights. The kind caused by someone elses passenger door.
Depends where it is, and what access is available to it.
Also if its in the very centre of the door, there is a metal bar running through to the side impact bar. It is imposible to get behind this to push out any dent.
Anywhere else shouldnt be a problem.
Dont pay any more than *£50 per panel*, no matter how many dents are in each.
from where you describe it mate there wont be an issue!
I have used this service many times now (bit of an obsessive!)
Most of the time it will be invisible - but as it is a trade learned through time and skill it really is down to the guy who does it - but yes get it done and stop worrying - it will be spot on!
they have two ways of doing it, they will either slide a bar down the inside of the door (with the window all the way down) or use a glue and a plunger to pull the dent out.
its amazing how quick, easy and tidy it is to have done!
