Passenger and High Level Brake Light
Okay so my high level and passenger brake light have both stopped working recently.
I've checked the connection to the passenger cluster, seems fine. Swapped the bulb from the other side, no change.
Indicator, reverse and side light are fine.
Seems like a simple problem, but no joy so far. Any ideas?
  172 Ph1
First check the multi plug behind the passengers side kick panel trim , unplug it , check the feed power circuit for the stop lamps , then move on to checking the power at the affected lights . If no power on the 2 that are not working , check the splice in the loom on the left rear , you’ll have to in tape the loom to see it .
If it’s a earth failed , that’s easy to sort also .
Good luck [emoji6]
