Passenger side door locking problem
Have a problem: i pressed lock from my fob while the doors were still open accidently and now my passenger side door will not lock or unlock via the fob i have to do it manual.
i tried fiddling with the catch inside the door but its made no difference, had a look at the fuse dont think thats gone.
any ideas?
thanks
In that case you have a locking motor problem.
First check the connector that runs between the A post and the door, make sure its tight.If thats OK, Then you need to look inside the door itself.
Does the electric window work ?
bummer, yeah the window works ok
it was working fine until i activated the central locking while the doors were open.
dont fancy ripping the trim apart but if i must.
will have a gander tommorow see whats what
thanks
