PC Problems
Car  Clio 1.2 16v
Hi,
Having major pc problems at the mo.
Computer kept freezing, wouldn't even boot up in safe mode. Tried formatting the drive, it would freeze during install.
So i unplugged the hard drive and it didn't freeze as it said 'no hard drive installed' which was fair enough.
So i went and got a new hard drive and started re installing windows and it froze again!?!
I've swapped the memory chip over to a different DIMM slot and it didn't make much of a difference.
Any ideas ladies/gents?
has it suddenly started doing this?
have you installed anything recently?
ide try some ram from someone to eliminate a dodgy ram stick
it's not my PC, its my father in laws.
I will have to try and get hold of a new ram stick
but i thought if it was the RAM then it would bleep during P.O.S.T
Sounds like duff memory. Swapping to a new slot wont solve the problem if it is. Could be memory, possibly CPU but not likely. I would however check the capacitors on the motherboard and make sure they are not leaking. The caps should be flat on top, if they are bulging or leaking a brownish fluid then your board is fecked. Last on my list would be PSU
Nope only if it was completely knackered. It is possible to have faulty memory and still boot
I had a similar problem with one of mine, solution for me was to take off cpu heat sink, regrease seal between heat sink and cpu then reseat.
