Yes. More so with forced induction though in my experience.
In my car the difference is noticeable. Some days it feels as though it could take on the world and others it feels very disappointing. .. cant help wonder if theres an issue somewhere. Only ever used v power.. lambda replaced..
It should never feel disapointing! maybe you do have an issue if its that noticable..
Worth pointing out that having stuff in the boot, tank of petrol, tyre pressures, leaky dampers, type of tarmac etc. all make a much more noticeable difference just to put it in perspective. You're not gaining/loosing 10 BHP depending on how nice the weather is.
Will quite likely be more than 10bhp in it between a very hot day and a cold day.
Here is the formula used on a dyno I work with that it uses to compensate for temp variations:
kWkor = kW(1013/air pressure) x sqr((273+temp)/293)
0 degrees => almost 4 percent more power than at 20 degrees
40 degrees => over 3 percent less power than at 20 degrees
So five or six percent very easy to see different and that's if the map was optimum for both, which it isn't as the temp correction is quite poor on these Ecus so could easily be more than that and hence more than 10bhp
With forced induction you double up the advantages basically. Cooler air going into the turbo means it's not as hot on it's way out. Then the intercooler is more efficient after the turbo as well.In my experience, the forced induction is noticeably better when the air is cooler, the N/A is hardly any different.
Both the Clios seem to run better with a full tank of fuel though and the Escort is no different. It's probably the placebo effect but I swear it just runs smoother. Strange!
on another note, is that how nitrous can have good results over other gases because its so cold/dense?
This makes sense, it's a twin pass intercooler as well.With forced induction you double up the advantages basically. Cooler air going into the turbo means it's not as hot on it's way out. Then the intercooler is more efficient after the turbo as well.
