Persistent Problem - thoughts?
Car  Blk/Gold 182 FF
Problem is - EML light flashes now and again when car is left idle for a few mins - doesnt happen all the time but car then becomes quite jumpy and light flahes untill i drive off or rev hard.
changes so far have been :
New Injectors
New HT leads
New Lambda Sensors
Anything else i could try or has anyone had this issue when it only happens on idle and not all the time?
Thanks Guys
if its intermittent it could be moisture in the coilpack. That's just another guess though. Get it looked at before you spend anymore
The manufactors book that comes with the car tells you what the flashing EML means. Cant remember what it says exactly though. Check it out and do your diagnostics from there!
