Ph1 172 Air Con button does nothing
Air Con has stopped working today - pressing the Air Con button does nothing - even the light in the switch doesn't light. Any ideas on what to check? Worked 100% fine about 1 month ago.
Danith
  GTi 7.5 pp/Mx5 nd2
im no mechanic so apologies if im being a mong! but if the lights not even comin on - fuse?
  www.renparts.co.uk
On models with a/c it's usually the blower motor that causes the heater to stop, climate models are usually resistor problems. There is a way to check if it's the blower but iv forgotten!! Its to do with shorting Something to check if the blower works...It's pretty simple I'm sure someone will be able to tell you! :)
