Ph1 172 revs high or fluctuating when the clutch is engaged/neutral
Jekyll
Hi guys, hopefully you can help.
My revs fluctuate or stay raised once the car is being driven. Stop/start traffic is annoying as it does this. Like the title says, it does it when the clutch is engaged or if I put it in neutral. I've changed the throttle body twice and the throttle position sensor twice.
It had a new genuine cable last year. It had a sticky throttle so that's why I got a second hand TB. I'm now on my 2nd second hand TB but still the same issue. The car has a DIY induction kit on with a breather filter running off the kindle control valve. Everything is connected.
Here's a vid which kinda show it. I do apologise for the stupid accent, I don't actually know why I talked like this!
Thanks, Mark.
