Ph1 172 won't start
  225 Cup & Williams
Just went out to start my 172 and it's not for going. It's turning over perfectly fine as it usually does but it's not firing up.
The immobiliser light on the dash seems to be flashing faster than normal. Does that have anything to do with it?
  R26, Williams #0227
I was thinking it was maybe the TDC sensor happened to me before. Funny thing is when I had the car it started first time everytime. Steven gets it and its all over lol.
  Moogun B95
Squeeze the key between fingers and thumb as you turn it in the ignition. might be breakdown of the transponder on the pcb inside the key.
common to see where the battery in the key has recently been changed and someones levered the pcb out to have a gander, damaging the wire-wound coil.
Worth a check.
  172 Ph1
Any updates on this? I'm having the EXACT same problem.
Should I replace ecu, uch, key and ring?
Or is it more likely to be a wiring fault?
How best to diagnose??
