Ph1 flat spot
Car  silver Ph1 172
Any gear pulls then its got a flat spot from 3k to 5k then its off again. Makes it a nightmare on the motorway cos 70mph in 5th its right in the flatspot! Anyone Had or got a similar problem? Thanks
Yeah i have the same problem sometimes and about the same revs. My car is running a little rich so it could be that if yours is the same.?:S
Seems to be getting worse! Had the plugs out and they look ok. Ecu light isn't on either so would a diaog be any use? :dapprove:
