ph1 mk2 coil pack location ?
  Clio 16v
anyone know where this is? its got the four coils into the top of the engine, and the wires dissapear down next to the engine, do they just go straight to the ecu?
  renault clio 1.4 si 2000
straight to the ECU mate, the pencil coils in the top "ARE" your coilpack, they have these bizarre individual packs. r they faulty? common for one to go.
  Clio 16v
nah just they wont spark, ive left the car standing for a month and never had a problem til this week when i came to start it, battery went flat etc, but thats fixed now, and the coils wont spark, dunno if the immobiliser had came on but nothing seems to work :S
one of the relays controls the ignition, i've had battery power but no spark, no power at any of the coils, swapped the relays over and it worked, they're 12 quid-ish from renault. might b worth a try?
  Clio 16v
where abouts are you based? what engine size?
im from houghton le spring just outside of sunderland mate, its a 1.6 16v engine 1999 model
where are the relays located that control the ignition? is it under the glove box and its a big red one furthest up the relay stack? ive had problems with that before but that was a while ago, however it was damp weather!
  Ktec'd 1.2 16v Sport
soz mate i was still half asleep, I read mk2 ph1!!!
As i have a spare coil pack or you could of tried mine.
  Clio 16v
hang on a min, i think i pu the tittle wrong, it could be ph2 mk1? i get confused by this, anywho its a 1999 model with the same sort of looks are your pic
  Clio 16v
yes thats the one lol gowd am thick, yeah, do you know where the relays are to get it started? i aint got a manual
the relays are under the bonnet, there's a plastic box to your right between the battery and wing, and they're in there with some hefty fuses. on mine there's 3 black and one yellow, but i think it may be different if you don't have a/c. one of the black ones is ignition. one is fan speed, as is the yellow. the other black is fuel pump. i can't remember which is which tho, you can test them by putting current through them and seeing if they click.
  Clio 16v
cheers thats a real help, i think ive got 2 black ones and a yellow one, below the hefty fuses, they seem to click for the fuel pump but not ignition, i will try see which one is faulty
fuse and relay box is under bonnet passenger side with black cover over top, on mine.
damn beaten to it!
haha got to be quicker mate!
  Clio 16v
checked the relays in the front of the bonnet, one was corroded to hell!! swapped it with another black one and it fired up, but what does the other one do that i swaped it for?
