ph1 spacer size
  Ph1 T
Im about to buy some spacers for the ph1 set of 25mm and set of 15mm,,
They are off a ph2 and the size is 60.1 bore 4 x 100pcd
will these fit my ph1 with no problems
cheers
dan
Daniel
  Whichever has fuel
Absolutely fine.
You putting the wider ones on the front yeah?
25mm on the front will be fine, my 15mm on the rear rubbed the arch though as my car was relatively low.
  Ph1 T
Spot on looks sound yeah mines quite low on the rear too if it's rubbing too much I'll just raise it slightly
