danh90 Car Ph1 T Jun 8, 2012 #1 Im about to buy some spacers for the ph1 set of 25mm and set of 15mm,, They are off a ph2 and the size is 60.1 bore 4 x 100pcd will these fit my ph1 with no problems cheers dan
Daniel ClioSport Moderator Car Whichever has fuel Jun 8, 2012 #2 Absolutely fine. You putting the wider ones on the front yeah?
dmallett Car flame-shed. Jun 9, 2012 #4 25mm on the front will be fine, my 15mm on the rear rubbed the arch though as my car was relatively low.
danh90 Car Ph1 T Jun 9, 2012 #5 Spot on looks sound yeah mines quite low on the rear too if it's rubbing too much I'll just raise it slightly
