Ph1 throttle body on ph2
Has any body fitted a ph1 throttle body & inlet to a ph2 (172 cup)?
How did you wire the iscv & the tps? I have a me221ecu (which does not like idling with the drive by wire)
I had a ph1 engine and inlet, but ran a ph2 throttle body on my cup. Had to machine an adaptor plate to make it it.
I have got a ph1 engine loom, ecu, throttle body, cable and pedals setup if you need one though.
@Pauleds,what are you after for the setup? Ideally only after the TB, cable and pedal but I'd understand you not splitting things
How much for the loom?
Make me an offer (loom and ecu)
