Ph1 to be fitted with ph2 engine
gudger12345
  Ph1 172
Morning
I have purchased a ph2 172 and was planning on disconnecting the complete engine and associated wiring to fit into my ph1
Would there be an issues or would i need to remove my ph1 engine loom and fit onto the ph2 (Engine dynamics Boosted DIY set up with AEM Management).
KitsonRis
From experience swapping to an after market ECU on my Ph1 I had to move pins around in the ECU connector as the GEN90 was made for a Ph2. So going on that I would want to say the loom is slightly different. If you have the loom and ECU it might be easier to swap it all over in the wiring somehow.
