ph2 172 drivers drive shaft
Car  White 172 ITB's
Hi, the inner cv boot has a small hole in it. I've done a search and it would appear you can't replace the cv boot you need to change the complete drive shaft, is this true?
could i not just use a ph1 drive shaft which is a single piece?
or even a ph2 172 cup drive shaft?
mine went last month 100 bucks for a new one hour labour not too bad ;)yeah you ve got too change the whole shaft apparently its a sealed one piece unit
Just spoke with K-tec and they say i can put a 172 cup drive shaft inplace of the shity one thats on there now. will just need to put the abs ring on;)
