i had a search and couldnt find anything, maybe am been thick, but any way i put ph2 172 seats in my ph1 obviously the airbag and serv light is on, the guides in the guides section is for ph2 right? thanks
try swapping your pre tensioners from your ph1 seats (Your seatbelts) as it'll have the same connection and I found it less fuss when putting sport seats in mine.
Resistor don't have a polarity any should do it. Why don't you get rid of the connectors and either solder the wires together or connect through a terminal block. I'd do it properly through safety in mind
