Photo Elevation
Hi
Ok, need to make a photo elevation of a building but will have to take either a prespective or several images. best way to put it togther or correct prespective?
Ideas?
cheers ppl
  1.2 Dynamique billabong
are you on about correcting the converging vertical lines mate. ie as you look up the building it appears to go in at the top.
its easy to fix on photoshop, just use the transform tool (ctrl + T) and pull the top corners out whilst holding shift
  Fiat Panda 100hp
tilt shift lens ftw (i don't know if this is the correct lens for what you need, but it's a cool lens nether the less)
