PHP Testing
  Golf GTD
I need to test a PHP script I have written.
I have a Windows XP system, can anyone show me some links to where I can test and run my script on my computer.
Im a bit of a novice:S
KDF
  Audi TT Stronic
Apache on windows wont run php stuff, you need php (with or without apache).. hence my link ;)
sn00p
  A blue one.
the_wanderer said:
can php could be run standalone? i thought it had to be attached to a webserver
Yes. I sometimes do it when php is the easiest way to achieve something simple, i.e a simple script.
KDF
  Audi TT Stronic
As said by sn00p, php can run independantly (in a CLI) of a webserver and is a good cross platform language.
  Golf GTD
cheers for responses guys, ill give it a go.
i just cant seem to get the PHP stuff to run, ive installed the windows binaries off PHP.net and when i run my php form (its a booking form for a website) it just displays the PHP code in text format :S
KDF
  Audi TT Stronic
if its a booking type form then your gonna need a webserver to display the output properly. You will have to install apache or find a php web host to upload it to.
  HyperAlloy Combat Chassis
Or you could use IIS already included with XP (oooo controversial ;) ) which actually works fine with PHP.
  UR 197, AB 182 FF
Oh my god
did nobody see what I posted?
EasyPHP will install php/apache/mysql all setup and ready to go.
THANKS MIKE :mad:
MikeDX said:
Oh my god
THANKS MIKE :mad:
Are you kidding? People only read the last post or two on each thread :rasp:
  UR 197, AB 182 FF
  Golf GTD
MikeDX said:
Oh my god
THANKS MIKE :mad:
sorry, i just assumed that it was better not to use an all in one package like you posted.
Ill download yours now :)
Probably on a live system, that's true.. but for simple testing on a single workstation, it's definetly a good way to go.. purely because it should just work straight away and be fairly easy to install.
KDF
  Audi TT Stronic
No, it really doesnt.. trust me on that one..
No problems here, I ran IIS6/MySQL/PHP for over a year and it worked great! It wasn't just a couple of scripts either, it was my dev box for a large student records system (which now sits on linux/apache :rasp: ).
KDF
  Audi TT Stronic
You probably werent exploring the full php capabilities.. sufficed to say there are lots of missing functions when using IIS. Also, for certain scripts I was running IIS just couldnt handle it.. on LAMP the scripts would run up to 100% faster.
