Pics after an Iron X session
Greeny.
  440i + 182
Car was filthy after driving around over xmas so gave it a good wash and it also had a good session with the Iron X, I forgot how much that stuff stinks! Not the best photos, loads of fog here so that probably doesn't help my point and click to focus but here they are never the less:
Dan
Greeny.
  440i + 182
Looks as though Photobucket has re-sized them loads for some reason, doesn't normally do it this bad :S
  Arctic 182, GTD
Looks good mate! Dumb question...never used iron X so I take is it like quick detailed or de-tar?
Sunglasses_Ron
ClioSport Admin
IRON-X is a pre-treament/decontamination product that removes iron particulate from the paint. You simply mist it on to the surface, watch as it turns purple, then rinse away.
The advantage is that it can penetrate below the clear coat and remove particulate that normal claying cannot. By deep cleaning the paint you are better preparing it to accept a product and/or removing any contamination that could affect the polishing process as you abrade into the surface.
  Arctic 182, GTD
Thank you very much lad! I'll be buying some of that then :)
  182cup & 172 racecar
Think it would have been better if you had shown the IronX at work really. Always interested in this stuff.
  Trophy
Don't leave it on more than 10 minutes though! Spray leave for 5 then gently agitate with a soft sponge or brush. Sometimes it's easier to do a couple of panels at a time.
I would recommend using a face mask when you are spraying it on, I've been really ill since i used it yesterday could be a coincidence though.
  Arctic 182, GTD
Ah right ok, cheers guys! I've just bought some so I'll give it a dig next weekend. Sorry for spamming your thread dan...lol
Gaz_
  Extreme mode
Looks good. Trouble with iron x is the smell!! I usually only use it once a year, in the spring to give the car a good going over after winter. The stuff stinks whilst you're using it, but then it lingers like f**k for about a week where you used it. Fail.
Tunst
  Focus ST225, Focus E
My car will turn purple when I do mine when the weather picks up..
