pinning programs to xp start menu?
  Ford Fiesta
how do i pin a program to the left hand side of the start menu, nd how do i delete one from there also?
Liam
  Pink & Blue 182, JDM DC2
Right click on ones you don't want and choose "remove from this list"
Right click on ones you DO want and choose "pin to start menu"
  Ford Fiesta
nothing happens when i right click,
Ive managed to remove the one i didnt want as it said the link was no longer valid and asked if i wanted it removing. But i still want to pin the other one to the menu.
  Clown Car
Click on Start button, then click on all programs, highlight the program you want to add to the start menu, go across to the right and highlight the program's .exe, right click and hold, then drag across to start menu and drop above the seperator line.
Alternatively -
When you have run the application before the .exe will appear in the start menu below the seperator line then do as DarthCake says and right click on .exe and select pin to start menu, and it will appear above the seperator line.
