Pinout wiring diagram for 197/200 ECU
Car  2010 Clio RS200
Hi all,
Trying to locate an ECU pinout diagram for the 197/200, can anyone help with a link etc.
Cheers.
Hi,
Trying to locate ECU to Coil wire for an rpm pulse so I can tap into it to add a progressive shift light.
Cheers.
That's easy, you take it from the triggers at the coils. You need two so grab one from cylinders 1/4 and another from 2/3.
It's very simple to work out which wires you need as there are only two at each coil. You need the ones that don't show any voltage.
Make sure it's a shift light for that type of coil. Plenty of shift lights are still only designed for old single coil and dizzy setups
Successful & relatively quick install today, for the record i only needed to use the RPM signal from 1 coil.
Cheers.
