Please help a noob with topping up oil
Maccy
  Straight 6
Just checked the oil level and it's a bit low, had a look in the book and it recommends 10W30, 40 or 50.
I've had a look at the guides on here and that's pointing to the same recommendation, however I don't know what oil was last put in. If it had 10W30 and I was to put in 10W40 would this be an issue?
Cheers :(
  172 cup, Impreza P1
Not the best practice to mix to be honest as it seperates at different temps but if you're low it's better to have some oil than no oil.
Get an oil change so that you know what is in there.
  MK3 GTI golf 16v
do an engine flush and fill it up with new oil, wont be expensive. half hours labour and the cost of the oil and a flush
  172 cup, Impreza P1
I wouldn't do an engine flush. Heard some nasties through doing that.
Just fresh oil should do.
-J-
  RS2'ed 172 Cup
Just changed the oil in stuntys 182 got the oil and filter direct from Renault Watford for just over £30.
If you get stuck give me a shout it's only a 15 min job.
  DON'T SEND ME PM'S!!
prob got it on the offer they were doing thats finished. We did the same price which with postage let us do it all for £39. We've had to go up a bit as the cost to us has raised now
Maccy
  Straight 6
I didn't check the thread before buying so got 10w40. Bugger. Is it best to take this back and exchange for 5w40?
  172 cup, Impreza P1
I've always used motul 5w40 and it gets up to temp quickly. 10w40 would do but won't heat up to temp as quick and will slightly affect fuel economy too. For long journeys you'd be fine but for town driving and short journeys you want maximum lubrication ASAP.
Maccy
  Straight 6
H'ok I'll try and change to 5w40. I did see some in halfrauds but it said that it was designed for diesel engines?
Maccy
  Straight 6
OK cheers Jay, will try and exchange on my lunchbreak today - I hope Halfords do exchange in store!
Maccy
  Straight 6
Just exchanged for some 5w40 and the car needed all 2.0 litres of the bottle! Oil level is now looking correct, thanks for the help guys.
  Titanium phase 1
I've recently changed my oil,I used mobil 1 0/40 long life,it's 50quid for 5 litres but runs nice and gets up to temperature nice and quickly
  PB Clio 172
i cant believe you let it get that low :nono: also if you wernt sure on the oil type just google it if you forget!
