PLEASE HELP! heater control removal ASAP!
Car  Clio Sport 1.2 8v
i own a mk2 ph1 clio and the dial for turning the heater up (faster/slower) has broke behind inside the unit of the heater controls, how do i remove this panel please? as its freing and i have no heater, any help would be great thanks!!!
Judging by photo u gta get to 2 screws below and then unclip from top?, any removable panels around bottom that wld line up with screw holes?
i got that far but it dont fit through between under the lower dash where it goes and the gearstick / handbrake etc. panels , so i was wondering if anyone knew if taking the gearstick etc. surround off i would be able to remove it , rather than the full dash for one tiny part
You can get it out through that gap, you need to remove the plugs from the back and shuffle it up towards the glovebox area.
thanks :) appreciate it as i just wanted to be sure rather than realize that i had removed it for no reason aha, done it today ,
