please help mpg/trip gauge
c6mby
hi
ive just bought a clio 172 cup and the mpg/trip computer isnt working
does this have its own fuse? if so where is it located?
does anyone know what else would cause this problem please
regards
sam
  Fabia VRS Special Ed
If it does, the fuse will be located in the fusebox on the side of the dash just inside the passanger side.
If you consult your manual it should tell you which fuse is for which function, if you can't find any then the best thing to do is check them all. Ideally you should check all of your fuses every once in a while anyway.
Just make sure when you're looking that there's no fuses missing, many people look at the manual and because there's a fuse missing presume it shouldn't be there, it could have been taken out and never replenished.
c6mby
Hi thanks for the replys, there is only total milage displayed on the dash, i have been told the car has a computer that had mpg range odometer etc, this bit on the dash is empty and displays nothing. I've checked all the fuses fitted an non are blown, I will try and find it in the owners manual
regards
Sam
