please help!!!!!!!
Car  1.6 16v
i was told my clutch was f**ked but it doesnt fall out of gear or anything!
just the biting point has come right up over the past year! how do i tell if its fu*ked?
need to no asap please!!!!
try and pull away in third... if you can slip it easily and pull away then its on its way out.... otherwise you should stall
drive along in say 3rd at around 3000 rpm and brake and accelerate at the same time if it starts to slip it needs replacing
