Please reccomend me a Intel motherboard.
I suspect theres some knowledgeable computer heads on here, Seeing as im a year or two out of touch with the computing world.
I am going to purchase a Intel i5 750, As i hear this is the only quad core in the i5 range? Good choice?
I need a motherboard, Would prefer full size not micro atx.
Needs pci-e, was wondering about usb 3.0? will be using external graphics, But good onboard audio if possible.
Any sugestions under £120?
Asus board is a great board run that one myself. However not suitable for an i5 based CPU anyway. Wrong socket i7's only. Even then only the 1366 based i7's.
Seen Scan's today only thing? If you order before 1pm on friday will still count. They have a package deal of i5 750 and mobo. Various boards to choose from might save you a few quid.
Gone for:
1 x Asus P7P55D LE Intel P55 (Socket 1156) DDR3 Motherboard @ 105.74GBP
1 x Intel Core i5 750 2.66Ghz (Lynnfield) (Socket LGA1156) Processor - Retail @ 135.11GBP
1 x G.Skill RipJaw 4GB (2x2GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit @ 82.24GBP
Saw a bundle of the above for £380, So specced it up from Aria and also got a artic cooler cpu heatsink and some DVDr's, inc delivery for £351. Not bad i thought.
Good choices?
The golden rule of mobos is never buy the high end stuff unless you're an overclocking *****. There are some great budget boards around that will perform faultlessly at stock speeds.
Sounds good Griff, Ive never overclocked before and dont really plan to unless theres an easy way, Is there any thing that can be easily done with what ive bought?
Im currently runing AMD dual core 3800+ and 2gb budget ram, Its served me well but is starting to lag for the things i want to do...
