plz help!
  • Thread starter Thread starter njh_89
  • Start date Start date
N
njh_89
I dont no what to do anymore ive had my car since january and have drove it for a week and it broke. My problem is that i can be driving down the road and it will lose power for a few seconds then will go back to normal again and when im slowing down to a junction it can stall but it only does these things occasionally. my car is a 52 plate 172. plz plz help me!
Any lights come up on dash? If not is more than likely electrical
Did have the lambda sensor come up on diagnostics both have been changed now and on the dash the abs light is on and the esp light comes on sometimes when it stalls.
Well they are known for duff coil packs, leads. Plugs can be a problem. Does it lose power then light comes on or other way round. If a light comes on you will have a fault code to read
ive changed the coilpack and i have magnacor leads which are quite new. ye it loses power then the light come on.
Try cleaning the plug connections on the throttle housing, crank sensor, coil, pedal sensor, and map sensor. Also check the ecu plug connections for corrosion clean and refit. Had exactly the same problem with a 172 2002 last week and it was corrosion on the ecu plug terminals. Could be a broken wire somewhere too but that will be harder to find. With the engine running wiggle the wires to everything you can and see if engine cuts out, could be a loose connection or corroded connection somewhere.
Lambda sensor fault will be down to the other fault causing a bad mixture and tricking the ecu into thinking the lambda sensor is at fault usually.
Ill have a look but im s**t with engines ant got a clue what or where any of that stuff is but ill have a look. cheers for the advice
Try a read out of the fault codes with a proper diagnostic computer (Renault Clip/RSTuner).
I ant got the funds to take it to a proper renault dealer for that sort of thing pal.
Could it have any thing to do with a worn gasket that ive found when wen i was changing the spark plugs?
Find an independant, should be an hours labour (or so) to have them put it on the magic clip machine
Ask on here if anyone with an RSTuner lives near you and wouldn't mind helping you out... can only ask mate
Good idea. any1 living on the east cost got a RSTuner that can help me out? i live in mablethorpe near skegness??
