Polish on Plastics
  Formally Clio 182
I've got some polish on some black plastics and there's white marks on them.
What's recommended to remove the white marks?
  Formally Clio 182
The actual polish is AutoGlym Super Resin Polish. It's like a white cream.
Will adding more of this really make the white mark go away????! :S
yes, its how i got it off mine. let the polish u have on there dry properly, i left it 24hours, and then jsut a very small amount and then rub it hard, and wipe clean
  106 GTi
Autoglym Super Resin on textured Black trim is how I am reading this thread ? If so applying more SRP onto the trim where it has gone by mistake will just make it worse.
MRBILLYUK
  FF Jeden Osiem Dwa
The only thing i've found that actually removes the white marks is a pencil eraser . All the trim products you buy just mask the marks .
WD40 is my prefered product for dressing black trim :)
MRBILLYUK
  FF Jeden Osiem Dwa
Doesn't WD40 leave a greasy film ?
Not really , use a cloth to dress it then buff it off .I've used greasier dedicated trim products . It blackens the trim and is water repellent . Use it after the pencil eraser ;)
  A well built VW
http://www.jmldirect.com/Magic-Eraser-PM4712/
This is what i use, mainly for interior plastics and the usual scuff marks , but today used it on polish that has been on the black plastic scuttlepanel for over 2 weeks and just wet it removed it with ease I also used it on my alloys to remove brake dust that was baked on and some runs with acid wheel cleaner from the previous owner. You can buy it for about £1 in cheap shops and it just breaks down so you know when its fubared
  106 GTi
Depends on the product Ali as said before, works fine for me, wipe it on neat if need be.
  Mito Sportiva 135
That actually looks quite good, kind of works like clay I guess from the video?
Well the white marks have dissappeared from my trim and i followed the method i posted above. I must be imagining things :rolleyes:
