polished up inlets
Gaz_
Car  Extreme mode
seeing all these polished up inlets has got me interested
can anybody do a guide detailing what tools/power tools and sand paper needed (ps i'm not a total r****d) etc you need for the job, i can feel a rainy day coming handy in the future
cheers
my input to this would be:
be very careful if using power tools as misuse and 'heavy hands' can lead to taking too much off and making bigger scratches which will take you longer to polish out when moving on to wet and dry!!
the metal is very soft so i found that there wasnt really any need for power tools!
to do the fuel rail cover i removed the cover via the two 10mm bolts with a ratchet and 10mm socket with a small extension (to reach the bolts)
i then proceded to polish away in my front room lol
i am currently doing the inlets whilst on the car, but making sure to put down covers under the pipes and regularly using a hoover to clean up any bits of metal/dust (u can just take it off if you want to)
to polish i am starting off with some aluminium oxide paper to take off the main 'ruffness' of the metal and then proceding to move on to the wet and dry. i have bought 120, 400, 600, 800, 1200 and 1500 grade wet and dry and basically i am moving through the grades once i feel that each grade has done all it can in terms of removing the scratches!
once the surface appears to be scratch free i am using autosol metal polish and giving it all a really good rub and repeating this loads of times using my electric buffer to bring up the shine!!
once this is all done you should have a good mirror finish :D
by the way i purchased my wet and dry for 2 quid a pack for each grade and you get 4 sheets in each pack from halfords, the autosol was about a fiver for a tube
i still have loads left and cut small strips of wet and dry up so as not to waste any :D
hope this helps in some way gaz
andy
pretty much summed it up
if your VERY VERY careful and gentle and keep the bit moving, you can use a flap wheel to remove all the roughness on the inlet tubes. saves alot of time but you do have to be very careful and keep it moving or you will create flat spots!
halfords also do 'variety packs' :) a couple of sheets of different grades.
i also found it best doing the fuel rail portector to have a bucket full of water. use the wet n dry, wet. and keep dipping the frp in the water to clean it..
very handy using the wet n dry, wet, as the fine scratches are shown up by black water settling on them so you can see when they have all gone, and know its time to move onto the next grade.
cheers, think i might take off the inlet, what tools are needed for this??
you need 10mm bolts for the inlet and coil pack
and then undo all electrics and piping (u may need to replace some of the clips when putting them back on tho)
