Polybush original or new OEM wishbones?
Car  monaco 172
Hi guys.
I've got some pretty bad torque steer. Car tracks perfectly straight off power and on motorways but as soon as I accelerate it wants to pull right.
I'm guessing worn wishbone bushes are the culprit.
Would I be better off polybushing the wishbones on it now and buying a new ball joint per side total cost of about 140.
Or buy 2 genuine wishbones which would cost about 140 and come with bushes and new ball joints. .?
If you only use it on the road @hipwell I'd buy a pair of new wishbones and leave it at that to be honest, if you track it then I'd use poly bushes.
I've just poly bushed a pair of brand new wishbones and there are easier jobs you can do, let alone trying to press out old rusted bushings.
Ah right .
Are they an even bigger pain in the are to get out than the OEM rubber dogbone parts? Those buggers took plenty of sweat to get out
Yeh its road only, can't ever see me going on a track with it to be fair.
I've got a set of strengthened wishbones, with poly bushes and brand new lemforder ball joints if you're interested
Ah right .
I haven't done any on a clio but the last set i done i just used the old wishbones and pressed them out and cut the rings. The new bushes were easy to fit but it was refitting the wishbones that was a b**ch.
