Popping noise after lowering.
Stuiemc
Car  Audi RS3, Clio 172
I lowered my car couple months back and straight after the front started popping, it only pops when i drive and turn at low speeds. Av driven it for about 2 months with no other symptoms just its started to get on my tits now. Anyone know what this could be ?
as above, sounds like there not sat on the strut platform correctly, also check the top nut is done up as tight as you can get it...
Yeah they could only go one way round. Al have to check the tightness but you know the rubber sleeve that comes on the spring should that be at the top or bottom on the front ones. As i put mine on the bottom and apparently it should be at the top not 100% sure though
