Possible rear o2 sensor fault
  Clio 172 Sport
Hi guys,
driving home this eve and the eml came on, didnt feel any different.
Had the aa round to read the codes and its come up exhaust catalytic converter malfunction (code 6126?)
He tested both o2 sensors and said the rear one isnt giving any readings.
Are tge sensors the same?
MicKPM
ClioSport Trader
  Clio16v/Zoe Z.E.50
The sensors are the same yes but if it's not giving any reading then this is an issue, most likely wiring related. If however it was giving a constant voltage then this is right... Well, depending on the mV output.
  Clio 172 Sport
Light has come on again after being off for a week...did look at the readings for the rear o2 sensor and there is 0v for it so like you said i'm guessing it's a wiring problem...hopefully swapping over the spare sensor will sort it. Any ideas where the other end of the cable is within the engine bay?
  Inf 182 Cup
Where's the best place to get the o2 sensor(s) from?
My front one has been causing trouble for the past few weeks, need to get it sorted as the EML has just came on again
  FF Clio 182
The sensors are actually different as in one has a long cable than the other. The overall function is the same so they are interchangeable
