Possible wheel bearing problem?
  Dynamique 1.2 16V 01
Strange noise when turning left. The noise doesn't seem to get progressively worse it has been the same for a while now. I have jacked the car up and tried wobbling the wheels but they seem fine. Any help welcome! Cheers!
If it sounds like a rumbling noise or grinding then it'll possibly be your front wheel bearing, mine did this on the near side front and it became worse as I turned in harder and faster, at 1st I thought it was the drive shaft, I had no movement on the wheel when jacked up but did have a damaged ball joint as well, on a 172 Cup.
Regards Russ...
