just bought some apex 60mm lowrering springs as i wanted to go lower than 30mm which i currently have, pictures of urs would be good please!
60mm?!?!?.... Doesn't that absolutely kill the ride comfort?
Also, clios knock on full lock, doesn't that make it worse?!...
How much does lowering set you back, if you want to do a proper job?...
springs cost me £40 deliverd, mine doesnt knock at all and shes lowerd 30mm atm, 60mm wont hurt
Properly with say.. a spring & shock kit BRAND NEW = £275 thats with VAT included. On top of that you have labour costs. Mines cost £120 but i believe it should cost alot more than that.
Did you do it yourself then? Or just know a man who can?!....
If they do knock a set of spacers usually helps things. Reducing the amount the springs can travel will of course make things a bit harsher but you have to bear in mind that the springs will be higher quality in the first place compared to standard Renault springs and shocks. Most people say that a 40mm drop on Eibach springs alone will improve the ride.
I just know a man who can
Mine has knocked ever since we took if off forecourt, when on full lock... very annoying. So what do spacers actually do? Sorry, i'm a know-nothing i'm afraid! :S
Just worried, the car has enough rattles in the back as it is, lowering and firming will make it even worse i'd imagine!....
With shocks?
60mm afaik
Mine.
60mm ish.
