Power boost valve + Exhaust system
Hi everyone! back from holiday and roaring to go in my willy again!!
Ok.. ive come home and my brother has ordered a power boost valve for his twin point injection cooper S.
i just wanna know what sort of power im likely to see if i get one for my williams, and how it will effect the fuel economy?
Also.... as its pay day this thursday.. i want a new exhaust system for my car.. so whats the best exhaust system for the willy. i want a nice deep sounding one. but with good power.
cheers
james
exhaust, go for an OMP systemthey are ace!!
as for the PBV.........nothing, waste of money......
if you really want to increase the base line fuel pressure, why dont you just get an adjustable fuel pressure regulator?
itll be 50% cheaper and do the same thing, if you campare the 2...they will look almost exactly the same!
What it does is just add more fueling every where.......which make the engine run rougher if its not drawing in more air to compansate for the increase in fuel. it should be the other way around.....fueling is the EASY part, getting the angine to process more air is the harder part......so, i personally wouldnt even bother with a PBV.
but you will get arguements from people saying it works, im not disputing that with some mods, a PBV (fuel pressure regulator) will just adjust fueling (in a very very crude way) go to nick hill if youi have any mods and want fueling adjusted sa the std fuel pump and regulator/return valve will be able to cope NO PROBLEMS!
Ben
