Power cable
  Liquid Yellow R27
Hey mate, take a look at this guide. It explains how to wire a power cable through. It just takes patience as it can be a bit fiddly. Good luck! :)
Hint hint then lol
On the other hand right up at the top of the passenger footwell is a rubber gromit with the bonnet release as said it located to by the washer bottle in the engine bay a little to te left of that mate further up
Nick
  Liquid Yellow R27
Yeah, you need to ideally make a hole with a screw driver through the rubber gromit in the passenger footwell. Then attach the power cable to the screw driver and push it through from inside the car. Top right of the engine there's the power steering fluid bottle that unclips. You can then get behind the carpet stuff at the back of the engine and feel down for the cable and bring it up, connect to the battery and you're done. It's a bit fiddly and takes a while, but it should be okay.
